I have these DTC showing for both side seat bets ( 10 faults each side )
does it point to a control module failure?
I have no lights on in the dash but the car doesn't go above 3k rpm when driving. I tried cleaning the wire connections coming from the seat belt buckle but it didnt make a difference. If I disconnect one of the connections, the fault becomes ( permanent ) which is expected I guess but re-conencting it just gives the intermittent message again.
Restraints (Safety belt tensioner (Beltpretensioner) - Right side (Belt
tensioner, right) - MT/AT) (after last fault code deletion)
534D - Faulty CAN message from SRS, seat belt buckle driver side
- Intermittent
5261 - The supply voltage of the control unit is too low (undervoltage).
- Intermittent
5348 - Stop lamp switch circuit
- No or incorrect CAN message from control unit ESP
- Intermittent
5061 - If there are no further fault codes, ignore fault code and erase fault memory
- Intermittent
5315 - CAN: communication fault with ESP (Electronic Stability Program)
- Intermittent
5314 - CAN: communication fault with ESP (Electronic Stability Program)
- Intermittent
5313 - CAN: communication fault with ESP (Electronic Stability Program)
- Intermittent
5312 - CAN: communication fault with ESP (Electronic Stability Program)
- Intermittent
5344 - Fault in CAN communication with Yaw rate and lateral acceleration sensor
- Intermittent
5345 - Fault in CAN communication with Yaw rate and lateral acceleration sensor
- Intermittent
- Intermittent
- Intermittent
- Intermittent
- Intermittent
- Intermittent
- Intermittent
- Intermittent
- Intermittent
- Intermittent
- Intermittent
