muzbaz
Hi,,
My wifes SLK has electric heated seats (no memory function), the drivers seat will fully operate except the raise and lower of the rear part of the seat, the passenger side works as it should.
I have noticed that it is the switch/button that fails to move upwards to enable the move, if you push down then the it gives the response you would normally get when a position reaches it's full movement, it seems like the switch control is stuck, it will not move upwards,,
The passenger seat control does what it should do to lift the rear part of the seat.
Any ideas comments etc of the best plan of action to get this working as the seat is now too low for the missus! Please don't suggest a cushion either )
Regards
Bazza
Regards
Bazza
