The collar at the bottom turns anti-clockwise 90 degrees. The knob then pulls off. (I'm assuming automatic)kevinE200 said:Can anyone tell me how to removal/install the shift knob on my W210 please?
It can be quite stiff. you might need something to grip it with - mole wrench or something, but be careful not to damage the plastic . . . use something in between tool & shifter.kevinE200 said:Thanks S.
Do you mean the bottom part of the knob? Mine is stuck! Do I need any special tool for removing it?
Perhaps you should do a 'HOW TO' symsym said:It can be quite stiff. you might need something to grip it with - mole wrench or something, but be careful not to damage the plastic . . . use something in between tool & shifter.
S.
Nah - sometimes needs a little extra help. If the mole wrench fails, just hit it with a LARGE hammer *Steve_Perry said:I think mole wrench might be a bit OTT.
S.
Steve_Perry said:Sad but I usually remove the gear knob to clean/polish it when I am detailing the interior of my car.
does any body know the part numbers for a oem w210 avantgarde gear knob, the leather one i have is worn out and would like to replace with same or better design maybe an after market one help would begrateful.Can anyone tell me how to removal/install the shift knob on my W210 please?
with avantgarde lettering.What colour is your leather?
have you any pics sounds ok is that an oem part and how much. not sure iff to stick with like for like or go for an alloy what do you think grav.I think I may have the one I took out of the E55 when I put the AMG alloy one in.
I'll check in a bit.
have you any pics sounds ok is that an oem part and how much. not sure iff to stick with like for like or go for an alloy what do you think grav.![]()
S.
ive got a kitchen work top just like that one but mine dosnot have a gear knob on it.
You obviously need to 'up spec' then..
