PaulE230
- Mar 27, 2007
Dont suppose this can be done on a 1996 w210 with elec folding mirrors ?
Thanks for that - I actually find that very annoying, as my dealer insisted that it couldn't be done on my Oct 04 car and it's bugged me all the time I've owned the car!
It depends on the front SAM and whether he is willing to give it a stab.
Would you kind enough to either post or PM me the necessary steps in StarDiagnose? I've found some info on one of the US Forums from Steve's Big Sis but it's confusing as there are discussions going on about several models at the same time.
Mine is a late 04 (so facelift) W203 estate.
If your technician does not know how to do it then I am wondering why go there. It needs to be selected in the cluster under variant coding and special equipment. Failing that you need to go see a mod specialist. I think the closest one to you is Alfie.
I also wanted some mods done on a 2007 W203. Namely the tyre pressure, Uk mode off, gallons left.
I emailed command.co.uk which I believe are connected with Alfie (Correct me if I'm wrong).
They quoted me £150 flat rate for an hour of Star programming !!![]()
How much were you charged at the independent ?
Cheers
Adam
There is a module sold in German eBay which does that. It is hardwired not manual coded. Speak to MBENZNL as he installed such a module in his W168.
mmm, I wonder if I can fit one to my W202
Turning down of the mirrors when in reverse.....can this mod actually be done?
We quoted you £150. Had you been a longer standing member of this forum (30 posts or more) the rate would have been different![]()
Hey, isn't that against the 'New user discrimination act 2007' .This makes it post number 23 !Star Mods still not done...
I will PM MBENZNL see what he says
I think it would be a great mod
I'm the same with a pre facelift 04 C180k Avantgarde SE with sports pack and am intrigued what I can have added via STAR and where I can get them done near Edinburgh.you've said what mods are available on the w203 post face lift 04 on, but does anyone know whats available on the pre face lift w203 as i'm interested in getting some of these done? Is there alot of difference?![]()
I'll email him if you want? I doubt he would ever respond to a PM on here as he hasnt been on here for eons.
Yes I was the test-dummy on that one too. I am on my 3rd mirror frame.
It goes something like this ........
* If you have folding or dimming then you already have the correct door controller. There is no such door controller on the W169 / W245. In the W164 ML you may have the correct door controller if you have the fancy door lights. Otherwise CLS W219, SLK R171, E-W211 (after 2002) all have the correct door controller regardless. If there is a mirror frame for memory passenger frame then order it.
