D
Deleted member 149005
Guest
I have found that my stop/start is sensitive to how “hard” I hold the car on the foot brake.....
There should be an option to reset or restart the TPMS in the menu. I think it says set new reference or something, it maybe the alarm point is off.40 miles to Swinley Forest this morning- nothing from the stop/start.
Also I now get a tyre pressure warning- it highlights the DSF tyre, which is off as it’s a)at the correct pressure and b) the same pressure as the OSF.
You've swapped the rims so it could easily be a duff TPMS sensor, but it's worth doing a TPMS reset and see if that clears the fault.Also I now get a tyre pressure warning- it highlights the DSF tyre, which is off as it’s a)at the correct pressure and b) the same pressure as the OSF.
Back to Bromley it is then. With a firm instruction that as you've paid (royally) for diagnostics once they need to work out why it's not working and fix it without further charge for diag's.40 miles to Swinley Forest this morning- nothing from the stop/start.
£10 a battery nowadays...I'd have got the old battery back but then I used to collect batteries and sell to scrap man when I was young.![]()
As in - pay for more exploratory work? Or any faults that may occur?Harrat’s won’t fund any further work, it’s now up to me apparently.
That’s a poor show and out of line with their obligations as a motor trader.Harrat’s won’t fund any further work, it’s now up to me apparently.
Not sure Mobilo would attend for a stop/start glitch? It’s hardly a breakdownYour car was dealer serviced, ring mobilo let them come out and have a play
Not surprised at the dealer not paying any further after being robbed for the battery..............
These look really interesting - thanks. Do they fit in the plastic tray like the other telescopic luggage dividers do you know?I got a set of these for the GT as they dot seem to do the floor rails anymore like they did in the CLS SB... solved the problem of shallow bag hooks and flailing shopping (its does fit S212 also):
Boot trunk snap in module 19 mm load securing genuine Mercedes-Benz
Protect your load in your boot trunk properly and saftey with the Mercedes-Benz plug in module for load securing. The 19 mm set is suitable for various Mercedes-Benz vehicles.www.kunzmann.de
