- Jan 21, 2005
- Location
- Mittel England
- Smart ForFour AMG Black Series Night Edition Premium Plus 125 Powered by Brabus
I’m not sure I understand what you’re asking.At what state of charge % range?
The higher SOC ranges, 80%-100% full, take longer to charge than the earlier low% -80% SOC range.I’m not sure I understand what you’re asking.
That’s what confused me about your question, as you suggest in your post above, a the battery gets closer to being fully charged the charging rate is deliberately limited.The higher SOC ranges, 80%-100% full, take longer to charge than the earlier low% -80% SOC range.
Even with V3/V4 sites being full I have always got the max power output. The sites have sufficient power supplies but if this isn’t possible they are supported by ‘Mega Pack’ batteries for peak use.
Each to their own.That’s what confused me about your question, as you suggest in your post above, a the battery gets closer to being fully charged the charging rate is deliberately limited.
Therefore it would be illogical to assume that @clk320x was suggesting (below) that his car charged at the max output of the charger during the phase in which charging rate is deliberately limited.
To prevent regen overcharging the battery when it is at a high SOC possibly?On a side note, on the Leaf, when over 90 % charged you only have 2 "bars" of regen available and below that the "bars" go up to 6. So I'm assuming that some of the regen energy is "lost".
Dunno if it makes much difference in the real world though.
Superchargers were just an example, but I would be interested to know what the grid supply to their sites is rated at (I tried to find out, without any luck). A 5 megawatt connection is unlikely I think - that would supply 270 UK houses all simultaneously running at maximum possible consumption (normal domestic supplies are 80A, so at 230V that's 18.4 kW).
I've certainly read a fair few comments from EV drivers about getting much less than the rated maximum power from ultra-rapid chargers, even with the relatively light usage most sites have now. I don't recall whether that was Tesla or not though.
Ok semantics but the exact wording is important because it confuses the debate of whether is squared or cubed. My understanding was that drag increases by the square of the speed but the power needed to overcome that drag increases by the cube of the speed.
Sorry Rob, yes I mean when I’m between 0% to say 40% I get the max output, naturally as the SOC increases the max output tapers. This is why you don’t ever really fill up above 80-100% on a fast charger as it’s just a waste of time. I usually just go from 5%-80% in say 30 mins.That’s what confused me about your question, as you suggest in your post above, a the battery gets closer to being fully charged the charging rate is deliberately limited.
I definitely think it’s worth remembering that even in 2025 there’s plenty of EVs out there with quite respectable ranges already. Perhaps not Vito vans with room for several dogs etc - totally understand your specific example which is very niche for the type of journeys etc but this is hardly representative is it?
As time goes by (and a relatively short time too!) EVs are getting better in terms of performance, range, charging speed etc and the infrastructure for charging is improving all the time too.
The excuses for not being able to use one are weak already and as you mention, compared to a few decades ago the expectations have changed already.
In other words, the preference for not stopping is minor. You’d have had to stop in the past and if you happen to live just a little beyond the current range for being able to do a 400 mile round trip without stopping at all (and with no changing facility at the exact arrival location too) then you would just have to change your habits.
And no doubt in the future there will be more changing infrastructure - including at the Excel centre
and hopefully they’ll have a Vito equivalent with a 500+ mile range so you might be able to not have to stop at all for even 30 minutes on the way back if you don’t have any way to charge at your destination![]()
In the case of the BMW i3, long before the tank wes depleted, the available performance was much reduced from that from a battery with a decent charge in it. That would be in the case of allowing the battery to deplete to quite a low SOC ( maybe 10%). It could IIRC be configured for the REx to come into play at a higher SOC as a provision for arriving in a city aiming to run solely on battery power.But you can walk into any Nissan dealership and buy an an X-Trail or Qashqai which does that
My understanding is that they will run continuously on petrol once the battery is flat - same as the original BMW i3 (although IIRC that had a pretty small tank?).
Drag is a function of the square of speed (v * v), and in turn power is a function of drag and speed (v), so when you combine that it’s (v) * (v * v) which is equivalent to v * v * v, or v cubed (v^3).So drag increases by the square of speed, and power increases by the square of the drag, right?
The reply was mainly aimed at the point that even at a full site you can get the theoretical max output across all stalls with the cars being at the right conditions.
I don't know about Tesla, but this is a map showing the current locations of high-speed charges (100kW to 350kW):Are all UK Tesla sites V3 or V4? Do all of these have Mega Pack batteries? How many charge ports are there at these sites (is it standard, or does it vary)?
Equally though there are many brand new EVs that don't have a very respectable range on a long run at higher speeds (particularly in colder temperatures). And plenty of older generation EVs that had less range to start with (not everyone drives a brand new car). Sorted by 'typical real world range' here (motorway range would in all cases be less, even in mild weather):
EV Database
Range of full electric vehicles cheatsheet. Quick reference for all plug-in hybrid en full electric cars.ev-database.org
See below:Are all UK Tesla sites V3 or V4? Do all of these have Mega Pack batteries? How many charge ports are there at these sites (is it standard, or does it vary)?
For example South Mimms on M25 has 36, Exeter on the M5 has 32 etc…
Using the CLS 55 AMG as an example, at 70 mph, the rolling resistance is around 452N and aerodynamic drag is around 427N, requiring 28kW (37PS) to maintain that speed.Yes and as long as we remember that aero drag is not the whole picture then we can show if the speed vs maximum power relationship is squared or nearer cubed without getting into serious formulas.
27 hp is enough to do 70mph,
To double the speed to 140 mph would require:-
If squared then 4 x 27hp = 108 Hp (good luck with doing 140 mph on only 108 HP)
If cubed then 140 mph = 8 x 27 HP = 216 HP
Now common experience tells us that the power needed to do 140 mph is certainly more than squared but somewhat less than cubed and that's because Aero drag is only part of the picture. rolling resistance increases more linearly so doubling the speed would only approx. double rolling resistance.
For the sake of simplicity lets say that of the total power required at 70mph, 20 HP was Aero and 7 HP rolling resistance
Power required to do 140 MPH is now 20 HP x 8 =160 HP + 7 x 2 =14 HP making a total of 174 HP. That sounds nearer the mark to me.
In reality it's more complex and doing this really accurately would require working everything out from first principles. The figure of 27 Hp to do 70 mph comes from some very old cars that would just about do 70 MPH on 27 HP and those cars had the aerodynamics of a brick plus the 27 HP wasn't at the wheels so the real figure would be lower. A modern car with much lower drag would do 140mph on a little less than 174 HP. Suffice to say that the above thought process shows you can't double a cars top speed by squaring the HP, it has to be nearer cubed.
Transmission losses | 18% | |
Engine power (at the flywheel) | 469 | BHP |
Vehicle track | 1.599 | m |
Vehicle height | 1.389 | m |
Vehicle mass (weight) (kg) | 1845 | kg |
Drag coefficient | 0.31 | |
Air density | 1.202 | kg/(m*m*m) |
Headwind speed | 0 | m/s |
Gradient angle | 0 | degrees |
Rolling resistance coefficient (tarmac) | 0.025 |
No, not all Tesla Supercharger sites in the UK are V3 or V4.
Many sites are V3 Superchargers, which provide up to 250 kW per stall and have become the standard for new installations and upgrades.
Some older sites (rare now) still use V2 Superchargers, which offer a maximum of 150 kW per stall and share power between paired stalls. Tesla has been gradually upgrading V2 sites to V3, but not all have been updated yet.
V4 Superchargers are a more universal design for non-Tesla EVs. Currently these are also set at 250kW but they will likely go up to 350kW soon.
V3 Superchargers are capable of delivering peak charge rates up to 250kW
V4 currently supports peak rates of up to 250kW per vehicle
Not all UK Tesla Supercharger sites are equipped with MegaPack or other battery storage systems. Tesla installs battery storage selectively at certain Supercharger locations where grid infrastructure may be constrained or where energy cost savings can be achieved by charging the batteries during off-peak hours and using them during peak demand. In many urban or well-connected sites, Tesla relies solely on the grid, without battery backup.
Megapacks have been installed at Tesla Supercharger stations that also have solar canopies to help power the Megapacks. Megapacks can smooth out electric demand on the local power grid and use the stored Megapacks electricity during peak demand so there are not excessive surcharges on electricity to charge the electric vehicles.
Some sites may use Powerpacks (Tesla’s smaller battery solution) instead of MegaPacks.
Larger sites, especially along motorways, may have 20–40 stalls.
