- Jun 24, 2008
- Location
- London
- 2022 Hyundai IONIQ 5 RWD / 2016 Suzuki Vitara AWD
Slower charging generally costs less than faster charging. Local authority charging generally costs less than commercial charging. Charging on major routes generally costs more than charging in side roads.
So it’s likely to be less expensive than the huge number of non-Tesla charging points you can see laid empty up and down our motorway network.
In Westminster, London, lamppost chargers were installed back in 2018. These are slow 5.5kW chargers, and the electricity isn't cheap - it varies, but typically around 40-45p per kW (depending on time of day). In other boroughs I saw retractable charging bollards, which is a similar principle. In addition, there are fast chargers in petrol station and street corners.
However, these city-street chargers work well only in densely populate areas when people live in blocks of flats, and the revenue from charging returns the ROI plus profit.
The issue is in suburbs and vilages where you have houses without a driveway. E.g., if there's a cul-de-sac with (say) 10 properties, and none have a driveway, installing charging bollards or lamppost charging will likely prove uneconomical.
Yes, there will be public chargers available farther afield, but not being able to charge the car near your home will be a major issue for many.
The solution might be similar to public transport and domestic electricity, where it's a condition of the operator's license that the service provider must also serve remote areas where it would not be commercially viable to do so otherwise. In other words, the income from the busy chargers in urban areas will subsidise the cost of installing and maintaining 'idle' chargers in suburbs and rural areas.
