dpbayly
Well as the title really, ive done this a few times to other cars and thought what the hell ill do it to my ML its done in this case by using my interior light to switch a standard automotive 4 pin relay which in turn runs through a standard automotive 5 pin relay to activate my side light circuit, i used 3 relays a 4 and 2 x 5 pin so that i could isolate the interior light circuit from the side light circuit once the ignition is switched on so there are no feed back issues when the car is running.
Things i had to wire in too to carry out this mod.
I had to tap into the foot well light (drivers side) a switched live off the ignition (which i fused) i had to find an earth point and i then used a power probe to find what wires that come out the light switch to turn the side lights on (there are 2 a left and right) this meant i had to use 2 5 pin relays to keep the circuits separate.
Here's a couple of videos of them in action:
My headlights are not on its the reflection of the light off my camera.
wired lights to come on and go off with unlock/lock Merc ML W163 - YouTube
and the rears:
and the rears:
