Henry D
I Believe its also a legal requirement for the towed vehicle to display an "ON TOW" notice on the back
OK, this may not be within the spirit of how things should work, but it's certainly not illegal.Ok, so I'm going there later today... the plan is to take a 3.3l petrol car as the "tower" just in case...
but to try to drive it home, depending on how much it's leaking... planned stops are my office (20 miles), friends house (14 miles), petrol station (somewhere) then home... intention is to stop, let the engine cool, topup water and continue.
If you're a member of the AA (or any other recovery organisation who cover the member, rather than the car), drive the new purchase until you "become worrried about the leak", then call out the breakdown provider of your choice. Depending upon the cover you have they will then drag you home.
A friend used this technique when he drag raced in the street class many years ago. After a slight incident at York Raceway, I dragged his car out onto the public road about a mile away and he then called out the recovery firm. Convincing the call centre that sending a patrol "to fix it at the roadside" was totally futile due to the rod poking through the side of the block was the only difficult bit![]()
Get yourself one of these, well worth the meagre price and the towed vehicle does not need to brake.
Clarke TB-2 Towing bar - Machine Mart
Daz
Since you'll need to fix it anyway , why not buy a new water pump and fit it before driving back - not a huge job on the 190 : remove radiator and all is easily accessible - I did mine in 2-3 hours in the dark on a freezing cold winter night . Haynes manual will keep you right . Pump was about £70 for genuine item from the dealer ( had to pay a refundable surcharge as I didn't take the old pump in when collecting the new one , but got it back OK ) . ECP had a cheaper pump but the guy on the counter told me I'd still have to go to Merc for the gasket which they didn't do , plus another bolt or pipe ( can't remember ) which they didn't have either , nor did they have their pump in stock anyway . Merc did have the pump in stock , discounted it to almost the ECP price , and everything required was in the box .
It is a manual... 2WD...
not a merc I'm afraid to say... I did want, and was looking for, a diesel 190... (and may have found one) but this one is an offer to good to miss on...
The 190 is something that a family friend has had in a garage for the last decade or so... low miles, FSH until it was garaged... still starts and runs... but it does have a problem I'm told, which is when you turn off the key the engine doesn't turn off... but thats a different project for the moment
M.
It's not a 190...![]()
It would be if I had more time... no way to get a pump by this evening unfortunately...
From what I can see, I would need 2-3 hours to change it, not too tough. Accesory belt off, a few hoses, 4 bolts & a gasket...
So the plan is to see how bad the leak is, if it's not too bad I'll drive & top-up... if it's bad it's being parked in Luton's car park for a day or two, then towed this weekend with the solid bar from hellfrauds...
M.
Why not take it straight to Hellfrauds and let them fit a new pump, service it, change the brake fluid, fit new wipers and all the other things they offer when you go in for a replacement bulb!
It's another probe (ducks for cover)What car is it?
If you are considering parking it up until the weekend, why not get a water pump and do it then?
You can only tow a vehicle with a rope to get you out of trouble, at all other times a towing bar or an a frame must be used.
I'm not saying you're not right (and I'm not saying that towing with a rope on a motorway is a great idea either), but can either of you point me to a statute that supports either the first or the second statement?Tow ropes on a motorway is a no no IIRC.
98
Vehicle towing and loading. As a driver
•you MUST NOT tow more than your licence permits. If you passed a car test after 1 Jan 1997 you are restricted on the weight of trailer you can tow
•you MUST NOT overload your vehicle or trailer. You should not tow a weight greater than that recommended by the manufacturer of your vehicle
•you MUST secure your load and it MUST NOT stick out dangerously. Make sure any heavy or sharp objects and any animals are secured safely. If there is a collision, they might hit someone inside the vehicle and cause serious injury
•you should properly distribute the weight in your caravan or trailer with heavy items mainly over the axle(s) and ensure a downward load on the tow ball. Manufacturer’s recommended weight and tow ball load should not be exceeded. This should avoid the possibility of swerving or snaking and going out of control. If this does happen, ease off the accelerator and reduce speed gently to regain control
•carrying a load or pulling a trailer may require you to adjust the headlights
In the event of a breakdown, be aware that towing a vehicle on a tow rope is potentially dangerous. You should consider professional recovery.
[Laws CUR reg 100 & MV(DL)R reg 43]
