miro
I have a W220 and W203 conversion to make into UHI. Can you share with me the pin location of the wires from 10pin RJ header to 10pin AMP connector.
I purchased over the weekend the part numbers for the connectors used in the UHI harness joiner inside the armrest.
001 545 59 40 housing 10 pin
000 545 93 03 cap
000 545 46 30 plug 10 pin
000 540 45 05 pins
168 545 43 28 plug
I didnt order the pins since they are normal MQS type used in all installations.
Did anyone publish the conversion pinout yet ?
I can publish now the pin colours for wires at the first joiner after the UHI connector back to the PSE.
W220 UHI armrest connector to 10 pin socket connector
1 - black
2 - light blue
3 - brown
4 - grey
5 - blue
6 - red
7 - green
8 - light green
9 - yellow
10 - white
W220 adaptor cable (UHI) from 10 pin armrest plug [to 20 pin socket]
1 - blue (thick)
2 - orange + white
3 - green + white
4 - purple blue + white
5 - brown + white
6 - pink (thick)
7 - orange
8 - green
9 - purple blue
10 - brown
10 pin connector -------------> PSE (D2B UHI version) DB25
1 - blue (thick).................power (Presumed -) ....pin 21 + shield
2 - orange + white............TX-...........................pin 11
3 - green + white..............LS-...........................pin 8
4 - purple blue + white.......RX-...........................pin 23
5 - brown + white.............Mic-..........................pin 1
6 - pink (thick).................Power (presumed +).....pin 18
7 - orange.......................Tx+...........................pin 12
8 - green.........................RX+..........................pin 24
9 - purple blue..................LS+..........................pin 6
10 - brown.......................Mic+.........................pin 2
Colours may vary but the pins dont since all UHI connections are valid from PSE to armrest no matter what colour wire.
000 545 93 03 cap
000 540 45 05 pins
168 545 43 28 plug
1 - black
2 - light blue
3 - brown
4 - grey
5 - blue
6 - red
7 - green
8 - light green
9 - yellow
10 - white
1 - blue (thick)
2 - orange + white
3 - green + white
5 - brown + white
6 - pink (thick)
7 - orange
8 - green
9 - purple blue
10 - brown
