quenching
Hi all,
I have an aftermarket remote central locking control kit that I'm going to fit to my '92 W124 E220 estate, I have it sitting in the shed and the locks are getting sticky on the car so I may as well install it. Thanks to advice over on the MB190 forum I think I mostly know what to do but I'm a bit stuck on where to locate it.
It breaks in to the blue control wire going to the driver or passenger door lock as in the diagrams below, I've locateted this wire in the drivers door but plan to use the passenger one, I assume the wiring is the same. The control unit is about the size of a pack of cigarettes so I plan to put it in the glove box and get power from the ISO connector on the radio, my cigarette lighter doesn't have a permanent live. I can then run the 18" antenna out of the glovebox to somewhere where it is "visible" to the remotes.
However, I'll need to remove the inside of the glove box to feed wires down to the rear of the radio and I can't see how to do this, is there a "How to" somewhere that would help?
I also need to run a wire to ground, where is best from near the glove box?
Finally, is it "glove box" or "glovebox"?
I've included the relevant instructions from the kit in case anyone has a better solution. The instructions for a W201 and W124 are the same.
Many thanks for any help, always much appreciated.
