Evening all,
Derek, in reply to your message -
The plate gives access to the valve gallery I guess for servicing/ replacement if needed.
Unfortunately tightening the plate bolts will have no effect as the gasket sits in a recess with a metal to metal contact maintained when bolted up.
It took me ages to find the leak as it tracked along the top of the seal before running down the side of the engine, mine had about 100ml of diesel fuel inside but this maybe more if you haven't removed any of the pipes first (see pic) to lessen the pressure.
Dieselman, I think this relates to the earlier pumps as the oil lub doesn't travel this far up into the IP, the fuel circulation is likely to act as a coolant for the pump in this area.
Agree, with Dieselman, the easiest way is to remove the plastic inlet manifold - a set of seals is around £10 for MB dealer and is a good opportunity to remove the EGR build up if you haven't capped it.
There are four nuts (10mm) on two brackets and then 20 odd torx bolts which I loosen with a socket then use a power driver otherwise it takes forever
I can remove mine in less than 15 minutes (did it today to replace all the hydraulic lifters
![Wink ;) ;)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f609.png)
Give me a shout if you get stuck -
