Dieselman
Banned
- Jul 13, 2003
- Peugeot 403 Convertible
Yep. Good job Silversaloon bought an Australian import hey...cobba.
Couldn't find any other than the small green one on the pushrod, which was in fine fettle so I left it.
I think they go under the screw on unions to seal the threads.
If you PM your chassis number I have the MB EPC up to 2005
Its strange that there are two different setups for the valve using the same chassis number![]()
The first is from the EPC and the second from the workshop manual so not sure what the deal there is, normally there is a reference to Euro/US modles but not on this one.
Derek, copy both pics and email to your MB dealer and order both with a view to returning those that dont fit.
thanks, but how do i get the actual part numbers?
Well the first pic is from the electronic parts catalogue which should be good enough to quote from numberwise.
When I order bits such as seals I use those numbers bt back it up with a pic in an email - its identical to the latest 08 online EPC apart from the obvious later models.
Good luck with that, I'd be careful of the small springs
You will need a special MB tool to get 'em out as well, there's a chap on here who bought one and lends it out -
I can never find these threads again with such common search words (valves
Just out of interest are you going to attempt all of this from underneath the car, I observed you had a reluctance to take off the air intake manifold
The job your about to undertake is by magnitude a 100x more difficult than the manifold..not that I want to put you off or anything....
Dont forget the pictures of you on hands and knee's looking for said things made from coiled springy stuff -![]()
