W124 rear end wobble?
lukather
Manchester
E280
I have a e280 W124 estate, yesterday after 120 mile round trip I pull forward on the car park, reversed slightly and then a clunk, the car now has a rear end wobble? even when stationary, seems to get less when in nuetral (its an auto)
Any Ideas,
p.s none of the wheels have been off and I can see anything wrong with any wheels tyres or brakes from underneath?
thanks
you need to get rear wheels off one by one to see all the suspension links.
get a mole grip or similar on each link in turn, and see if you can turn it.
this will show play/breakage in link joint.
I'd check all the suspension bushes , subframe bushes , propshaft couplings & mountings , diff mountings , driveshafts - whole back end really .
What I WOULD NOT do is to drive it further until the problem is diagnosed .
Broken rear spring? loose differential mounts? rear subframe mounts?- usually the front ones and not the mounts themselves--but where they mount on the body frame- not easy to see until you jack up the car and inspect carefully.
