Db7gtgrigio
- Dec 18, 2012
- 300CE-24
Hello
Have used this resource a lot to keep my 90 300CE-24 COUPE running well but have not yet posted. I have an issue that I cannot find any relevant posts in the achieves and would appreciate any suggestions. There are posts about the general issue but do not seem relevant to my circumstance.
Passenger front seat (RHD) will not lock in position when it should. Drivers side locks when engine on doors closed etc. I have checked the vacuum lines under the rear rest squab there is plenty of vacuum. The head rests deploy as they should (also vacuum controlled) and as I say the drivers side is fine.
I removed the hoses to the seats at the take off under the rear seat and applied a vacuum using my mity vac. On the drivers side I could see the locking mechanism moving as I applied vacuum. Once I got to about 85psi the mechanism moved no further. It moved far enough to lock the seat back in place. The vacuum held steady at 85psi.
When I tried it on the passenger seat the locking mechanism moved only slightly. Not enough to lock the seat back. The vacuum also held steady at 85 psi.
The fact that the vacuum held steady at 85psi seems to suggest that the diaphragms are not leaking. The problem therefore seems to be mechanical. Something is causing the vacuum to not pull the mechanism sufficiently to engage with the locking bar? the locking bar is rotated on a shaft by a cable that is obviously pulled by the diaphragm when under vacuum. There does not appear to be anything impeding the rotation of the locking mechanism and the cable looks clean and seems to pull smoothly for the short distance it is actually moving.
Any ideas?
Chris in sunny Sydney Australia.
Any ideas?
