W202 Fuel filter mounting plate
Joe_SP
Wokingham
2013 E250 & 1999 M3
Hi all
I went under my 99 C200 at the weekend to change the fuel filter. The steel bracket that it is mounted on - together with the pump is very rusty. I have sprayed all the screws with loads of WD40 and plan to return to it next weekend. I was thinking it may be more sensible to replace the mounting plate.
Is this a common problem and is it a good idea to repolace the mounting plate?
Cheers
Joe
Hi all
Cheers
Joe
Not a bad idea make sure you get new screws and any pump /filter insulating rings if required as well as the bracket. there are many bracket permutations so go to your dealer armed with the chassis no. Cost will be £10-20 max I take it the fuel pump assembly is protected by a plastic cover on your car.
http://www.detali.ru/cat/oem_mb2.as...417717.418&CT=F&cat=44V&SID=47&SGR=030&SGN=02
Hi
You it is all under a cover but is really rusty.....
Joe
Mine's quite rusty around the pump mounting as well - have given it a good waxoyl, but would like to get under and clean it up a bit at some point.
Do you have the mud shield fitted,, you could just spray the whole lot with Waxoil
