Laters
R2D2 said:I take it that you havent got any engine mods?
The car is as I bought it. Think its stock. Its my everyday driver so dont really want to modify it engine wise. (thats what my quantum is for
![Wink ;) ;)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f609.png)
R2D2 said:ohh good question.?? If the wheel is larger, then in one revolution it will have travelled further than the standard tyre. That means your car is underrecording mileage because its basing the calculation or a smaller diametre wheel. As for speed???????
Thank god for a bit of give and take on the speed cameras.So if its reading under I could have been stoping the clock at nearer 65mph than 60 mph.In which case I doubt that I shall ever get a decent 0-60 time by using a stop watch.Dieselman said:The same will be true. The speedo will be under reading.
Maff said:Anyone is welcome to borrow it if you want, used it three times and never been used since!
pluggers said:Thank god for a bit of give and take on the speed cameras.So if its reading under I could have been stoping the clock at nearer 65mph than 60 mph.In which case I doubt that I shall ever get a decent 0-60 time by using a stop watch.
GrahamC230K said:The things we do for Greg on a Sunday......
I think we all accept we are comapring by crude measurement (apart from Maff) but here goes.
I did one run. Full tank of fuel, road actually had slight incline (doh!), just me driving.
I figured if I dipped the clutch as I past approx 62 mph instead of changing to 3rd I could operate the stopwatch on my phone in my cradle. Worked easily really.
I dumped the clutch at 4000rpm (hence only one run!). The 245's did a good job and mostly held traction. Holding onto 2nd into my newly avilable rev range (from the remap) up to 6500rpm I stopped the clock as I passed 60 mph. Allowing for reaction and knowing by GPS I only over read by 3mph at 60mph, I think I timed to an actual 60mph as good as can be expected with such crude techniques!
The time: 6.8 secs.
I am pleased with that and happy to do it again with Maff's kit if (when) I get the chance.
Will said:Bl**dy hell Graham - that's not bad at all! Quicker than the 'published' figure for a C36!
Would you have been able to hit 60 in 2nd before the re-map? If not, that must surely save you several 1/10ths of a second?
Will
GrahamC230K said:No. The remap has moved the rev limiter to 6500rpm so I can now hit 60mph in 2nd where as before it was 3rd.
It sure felt quick when launched at 4000rpm. A real hang on moment!
I got lucky too, the car wanted to go, so I dropped the clutch right, but didn't overly wheelspin.
