spuggets
- Mar 3, 2012
- C32
Hi All
I can't work out if I'm just being thick here, but every few days our W203 seems to forget it's memory seat settings. I have it set up so that the seats are tied to the keys - I assume this means simply that whenever the car is unlocked, the seats resume the position they were in when that same key was used to lock the car (regardless of whether another key has unlocked it in the meantime)? That's how it works on our other non-Mercedes car.
However, what seems to happen is:
1. I will set the seat up for me and save to memory position 2.
2. I use the car and the seat appears to return to the right position when I unlock it (assuming the wife has been in and moved it since I last used the car)
3. I don't use the car for a couple of days, then unlock it, and the seat moves but to the completely wrong position
4. If I interrupt the movement and select memory setting 2, the seat still attempts to resume the wrong position
So it's as if my setting 2 is getting forgotten or overwritten somehow.
Just typing all that has made me wonder if the missus is getting in and repeatedly storing her seat position over mine... but assume not for now, does anyone know if this is a common issue or just me being dense??
Many thanks
Spugs
Many thanks
Spugs
