Hello, I was going to buy some oil to top up my reservoir (estate model) but then thought about changing it as it has had no genuine B-service...just what I have done myself.
I rang the local stealership that were £2/L cheaper than the local indy, then asked the capacity of the system as I was thinking of replacing the whole lot.
He said 1.2 Litres which I thought to be a little odd as it does the rear suspension as well as the power steering, can anyone confirm this?
Also, is it just a case of sucking out as much from the reservoir as possible or is there a bleed/drain plug?
Lastly, when I do fill it back up will the system bleed itself?
Many thanks in advance for any replies.
