w210 Estate rear washer leak
D
Deleted member 57040
Guest
The rear washer does not deliver water and water is leaking out the bottom of the rear door. I'm assuming the pipe is loose at the nozzle, but how do I get to to it?
Do I remove the whole rear door trim? What about these plastic poppers?
Thank you.
On the C55 you have to remove the entire trim. The pipe has either come off the motor or the joint at the motor has cracked - requiring a new motor. Really pants design by Mercedes. I have never had any other make of car that leaks every time you get a frost.
Thanks brucemillar.
Any clue as to how to remove the rear trim? These plastic poppers are tricky little things.
They will normally pull out with some long nose pliers. You pull gently on the inner stud when that pops up you can then pull out the entire plug. Fiddly for sure.
OK, thanks. I was trying that but feared breaking them...
Will adopt a gentler approach.
They are stubborn! Only one broke...
It would appear that rather than just 'coming' off the pipe has broken off.
There is a small black plastic grommet that has broken. Are these available for repair or is a new motor needed?
Thanks renault12ts.
