celicajames
Hi I have just purchased a e320 estate that I'm very pleased with, so far I've fixed the load cover and the SRS warning light (OK so the rest seat wasn't latched properly but I'm still counting it as a fix). The only niggle I have left is that there is a bigger gap at the top of the n/s light than the other, I couldn't see any bent metal or anything that showed a crash although you can see a small crack coming from the parking sensor, does anyone know of an easy way I can move the light fitting to sit more central or suggest some other way to make the gap smaller?
James
https://docs.google.com/file/d/0BzCAlJ47toOrbm8wdDlTLXFDelk/edit?usp=docslist_api
James
