- May 28, 2004
- Location
- Essex
- 1984 500SL, 2007 E320 CDI Sport Estate, 1995 SL320 R129
Little advice please guys. I have serviced the E320 CDI 2007 and reset the service indicator a few days ago, no problems.
Today I decided to check that the right oil setting was used as I did not change this. So when I looked I needed to change from standard oil setting to 229.5 in the display.
Problem is this....it would not accept a change to the oil setting and when checking the settings the originalservice B has changed to a Service A in 15550miles ao there abouts.
How can I change the oil setting to 229.5 and revert the next service setting back to service B please. I have followed the WIS sheets but these have not really helped with the problem.
Do I need to revert back to the last service,then put the service and oil type in again?
