Hi there,
I did it all for the E320CDI nearly as lupi advised..
lifted the car, remooved the covers, both had to be remooved to reach the plug. After I drained the oil, discovered I was sold the wrong filter
the only solution was to put it all back and go get the right one (motor factors adviced me to put the new oil in, fit the old filter and go back to them for the right filter... I found it a bit strange). So I did it all again the next day. It's all fine... and just to make sure I had the right ammount of oil in, I filled 5l, then checked in the menu and was told to add 1.5l, that makes it 6.5l of oil altogether. By the way I did change all 3 seals on the filter fitting. Also replaced oil cap, as oil discovered arround it. Thanks for the help.
