W215 sticking drivers window and lazy NSF wing mirror...
grainqey
south yorkshire
Cl500
Hello,
Sorry if this is the wrong section.
I sometimes have a sticky/lazy drivers side window, the passenger side is fine but the drivers window will either stop or go back down slightly(anti trap function)
do i need to lubricate the lower rubber along the top of the door?
also, i have a lazy passenger side wing mirror motor i think...
it slowly functions as it should but then when its about 75% folded out it basically cant manage the motion on its own, maybe its a worn gear? what the motor rotates the mirror with?
thanks in advance
Alex
Lube the rubbers in the guide with silicone and the window reg with grease.
It maybe miss aligned causing tight spots.
