Washing oil off engine bay ?
Omega
West Cornwall - U.K
Hi all,
Somehow, the oil filler cap came of my engine last week. Oil spilt all over the engine bay, including all over the front end, inc belts/pulley’s/frame etc.
The first I knew was a warning came up on the computer read-out, saying: “check oil level at next service”.
I stopped to check the oil level – it didn’t reach the dip-stick !
In my opinion, this is too low to leave until the next service. Is this readout the only thing we get ? Did Mercedes think that a warning light was so out dated ? Surely a warning before this level is needed.
I called my local MB outlet (Probus) for advice on cleaning the oil off the front end. I was concerned about slipping belts / degradation of rubber (compounds), plastic cabling etc etc & he kindly offered to wash it off. I took it over & he said that it was now clean & he’d put a new filler cap on.
When I checked it yesterday, it was obvious that the front end hadn’t been touched at all. The oil is still all over the place.
Which brings me to my quest:
Q1/ What ought I use to wash the oil off, that won’t effect the rubber (compound), cables, paint etc ?
MB mentioned muck-off (I think that’s what he said to me ?!#@). It seems to be a bicycle cleaner – tho’ it is made by Wurth.
It would suit my health, if there was a spray on product.
Q2/ I am also looking for a Waterless hand cleaner to keep in the car. Some years ago, I saw a chap with a tube of stuff (bit like toothpaste). He reckoned you just rub it in & it removes oil, dirt, grime etc, then just wipes it with a paper towel etc.
Any ideas please ?
cheers
If you have a dipstick? then start to top up the oil a litre at a time till it registers on the dipstick. Then normally its approx 2 litres between the full and empty marks- your handbook may give details. The oil warning light should have come on if the oil pressure had dropped below safe so no damage done. Personally I would not go down the steam cleaning/pressure washing route but use lots of wipes/cloths with a proprietary cleaner . Most rubber components wiring insulation are made from oil resistant material so just require a clean up of the bulk fluid. Buy a box of nitrile disposable gloves at your local surgical supplies to protect your hands about £7-8 for a box of 100.
Wurth make an aerosol engine cleaner 089023 http://issuu.com/wurthuk/docs/auto
and
http://www.wurth.co.uk/catalogue/pdfs/UK-CD_08_0055.pdf
