Weistec SuperCharger has ARRIVED!!!!
Well done everyone at MSL
Well we hope to do a few more Weistec conversations in the New year. Will see if we can get a group buy going to save some money.
Acid
We'll done Acid for uk 1st and a great offer.
Lee we'll done also for taking the plunge can't wait to see it under full chat at some point maybe vmax??
Thank you
I hope we can take it to Vmax as i am sure it will hit over 200mph :D
Thank you
Well if it does not hit over 200 looks like its stage 2 sooner than expected.:eek:
Make sure you do something to make the car more stable, C63 have a tednency to go very light at the front.
Looks AMAZING!! I bet it goes like a bat out of hell!!
Does the charger need run in? and is there no way of fitting the engine cover? Or was it just never going to fit with that big lump there : )
No run in period for the charger just bolt it on and go.
Its night and day the difference in the car, you can just drive on the torque....no need for kickdown just squeeze the throttle and ride the torque......mind when it kicks down you feel your fingers squeeze the steering wheel and your but tweeks twinge ha ha.
The engine cover just needs a bit of modification due to the supercharger pulley, so it will be fitted in the next few days after a bit of gentle filing of the carbon cover :eek: The original will be used for a practice one first ha ha
That is amazing, credit to Acid and the guys, sounds like they did a great job in short time, amazing!
I'm sure you will have lots of fun.
You've fitted a diesel engine??
How many mph/1000rpm does the car do in top gear and what is the max revs?
It must be significantly over-geared in atmo form.
Depends as some years have a different final ratio, the 2012 had a final drive ratio of 2.85 and 7th gear is 0.72. It will achieve 34.8mph per 1000rpm. Max rpm is 7200.
So theoretical 250+mph
