F1BHP
- Oct 26, 2014
- SL600
I have not seen it in the flesh yet. Just keeping my fingers crossed it will all come together. For me the main thing is the engine work and creating a high power reliable super car.
I definitely know what you are saying and if their was any evidence of weakness in the engine then I would upgrade it. The fact is that i challenge you to find any engine failures in the m275 because I can't find any. Tuned or not.
The torque will have to be limited on the tune as it will probably hit over 1,200nm without limit, this is normally the problem for the gearbox. The gearbox should cope with the BHP with the torque kept in check.
I have no problems upgrading the internals of the box if needed and quite a few have done before on the 600's prior to 2007 year when the 600's got the same upgraded sl65 box which has proved very solid and the same one used in the sl65 black. My TCU upgrade has also taken the adaptations from the black series box along with the raised RPM limit.
Hey I am not saying it can't happen I am just saying without going down the shorty manifold and much bigger turbo housing it seems like messing with the internals is not needed.
In fact I would be more worried about the non stock, upgraded items failing as they don't have to go through the same testing as from the factory.
The whole motorsport industry is built around blueprinted engines stuffed with precision made parts, usually of much higher quality and cost than their serially produced counterparts. For someone who modified his ECU software with an aftermarket offering, your last sentence doesn't make any sense.
the reason of the racing engines are rebuilt after every race it's because they are pushed to the limit and they as little material as possible to save weight and also the tolerances are set to last a race ,so what you saying makes no sense at all !F1BHP said:The point about the Motorsport industry using blueprinted engines stuffed with precision parts as a reason to do it, makes no sense. I have been involved in Motorsport and know all too well that our engines get rebuilt on a regular basis. Yes, they are being pushed to the limits but once you crack open that can of worms things can get more complicated. Personally with this engine ( which is not working hard in stock form at all ) I would be more worried with modified internals of a failure than without.
you aiming for brabus figures without the brabus internals ,so in my book your engine is more than likely to have issues,just a little advice make a good base to achieve good results sometimes the big numbers in the dyno don't translate in max performance on the road!F1BHP said:I made the same point about the race engines being pushed to the limits, however mine should not reach that limit. If I had the budget to get brabus to do my internals I would defenetly get them done as extra security, however i don't want to drop £50k plus on that at the moment. Why you feel the need to come on here and make stupid comments about Motorsport experience, when you don't even know me is not worth commenting on.
The one giving it the large is you and what I can see from your posts you should put a bs badge in you car!F1BHP said:I made the same point about the race engines being pushed to the limits, however mine should not reach that limit. If I had the budget to get brabus to do my internals I would defenetly get them done as extra security, however i don't want to drop £50k plus on that at the moment. Why you feel the need to come on here and make stupid comments about Motorsport experience, when you don't even know me is not worth commenting on.
