All season tyre fitting = MB stalling measure - whilst engineers continue to scratch heads (and get butts kicked for poor engineering of RHD cars)
I'm finding this quite bizarre, new car owners talking about regular tyre changes to compensate for a defect on their new 40k+ vehicle. Eventually the structure of the tyres will be affected by continual being fitted/removed and there's a risk of your lovely alloys being damaged.
Apologies to those that have read this in my previous posts. My 3 week old GLC started life on MO tyres and skipped during full lock manoeuvres in low temperature conditions, run flats were fitted by the dealer as the temperature increased to double figures and the skipping reduced significantly which was either the tyre change, temperature change or combination of both. I drove 270 miles yesterday some of it in the wet with the temperature back in single figures and I noticed during full lock manoeuvres in the wet my GLC still skips and what's more unnerving is whilst turning out of side streets into heavy London traffic a number of times I felt the front end of my GLC skip/skid slightly and I wasn't going particularly fast and I suspect the road wasn't particularly greasy, I put it down to the skipping issue.
I for one will be going for the all season tyres for all year use, I wouldn't consider continually changing tyres to accommodate the seasons, I haven't had to do this on any of the other 25+ vehicles I've owned why should I have to start because I've purchased a Mercedes Benz. If the all season tyres don't improve matters as MB suggest it will I shall be continue to pursue the matter and if necessary seek legal guidance.
MB themselves said in their letter "Due to the positioning of the front axle differential on right hand drive cars, the steering position differs very slightly compared to left hand drive models. When the steering is on full lock this steering angle difference can result in the front tyre skipping sensation". This admits that a design change has caused the issue, as left hand drive GLC's don't do it then I'd assume right hand drive GLC owners are well within their right to expect right hand drive GLC's not to do it. I for one would be interested to here the opinion of a legal representative on the contents of the letter.
You may be right.All season tyre fitting = MB stalling measure - whilst engineers continue to scratch heads (and get butts kicked for poor engineering of RHD cars)
Am I the only one who avoids full lock?
Serious question, ever since power steering became popular applying full lock has always felt like it's putting undue pressure on the steering system. I prefer to take a little more time and be more sympathetic to the car.
Just because you can go to full lock doesn't make it a good idea.
You may be right.
Having watched this saga unfold, I'm minded to the view that there are actually two issues.
The first one is related to the different steering geometry between LHD and RHD cars. MB Engineering knew this and knew that it would cause a juddering / skipping issue in cold weather in or near full lock, so when complaints started rolling in they had a pat solution which was "change to winter tyres".
Separate to this - and the fact that some (but not all) cars exhibit much more serious symptoms and in normal driving conditions tends to support this - there is a build / manufacturing fault present, but only on some examples.
So, it's a classic misdiagnosis scenario. Every complaint was being dealt with as though the root cause was the issue known about, and no one considered that there is another fault present - one of example rather than type - that gives similar symptoms.
If I'm right, then there is a real possibility of a solution for current owners. If I'm wrong, swapping tyres is as good as its going to get.
Yep this is a weird one as you would expect ALL GLC/C 4Matic owners to have the same problem. But they don't. Some have mild crabbing (like me) which they sort of live with. Others have significant cluncking/severe crabbing which many owners will not live with. And some don't have any problems at all!! How can identical cars display such different characteristics in similar conditions during normal usage? I know that wheel size may be a factor in terms of the tyre's etc.. as some GLC owners have gone for 21's but that aside I puzzled by this.
Is the difference either:-
Skipping - the effect of the geometry, and the tyre relieves the sideways force
Clunking - the tyre maintains grip until the clutch in the transfer box slips and makes a loud metallic bang
This will account for the variability of both symptoms and degree to which the user suffers the effect.
Even though you are perfectly correct it doesn't really address this issue. MB have a problem here and it's growing by the day. Their AW tyre solution will only buy them time. I don't see this ending well for MB.
For others it might be like a tooth with a lost filling that you cannot help poke their tongue into. This might account for the excessive tyre wear.
You may be right.
Phil - The technicians and salespeople at MB dealers will tell you, off the record, that all GLC's exhibit this fault. All customers comment about the problem some loader than others. I've been told it's impossible for MB to move or reposition the axle or steering / suspension components, and looking under our car with the dealer clearly shows this to be the case - The related parts / components are so well engineered, they fit seamlessly together, with no options or room for adjustment.
It really is a simple fact of incorrect design and egineering by MB as their recent statement highlights - the front axle and diff are in the wrong position. Sadly, someone at MB got it wrong on our right-hand drive vehicles
So I don't think this is a manufacturing fault impacting specific cars
Different tyres is the only way forward. The wheel size does have an impact, larger being more pronounced crabbing, but even the 18" wheels crab.
Many customers simply close their eyes and ears to it - bit of the kings new clothes scenario - these die hard MB customers couldn't possible have a faulty car because the dealer has told them it's nothing to worry about, just a characteristic that MB are aware of.
Also important to think about the the group of owners we all belong to, who will register and voice their opinions and ideas on forums like this one. We are most certainly a minority - most GLC owning families would never dream of asking for help or reporting issues on a forum. There might be some statistics linking owner types to forum use - my guess ( could be totally wrong ) is that most forum members and Auto mag readers tend to be sporty vehicle owners and not middle aged husbands and mothers who are the primary demographic for GLC owners. So the scale of the problem will go unreported unless it's possible to gain access to this group of owners, which is unlikely to happen unless Watchdog or similar TV / media coverage can be produced.
Trying to indicate the scale of this fault and I would guesstimate 95%+ of GLC owners will never read or post on a forum like this.
Tony
Very true though your statement "Different tyres is the only way forward" depends if you're looking at it from the MB angle or as a customer who's spent their hard earned cash on a faulty GLC. If something can be designed wrong it can equally be redesigned right. So the way forward is find out where the fault is and get those MB engineers to redesign the affected components then replace the faulty ones. Of course there will potentially be large costs associate with doing this, that's MB's fault not ours so they should get on with it and do the right thing rather than attempt to mask the fault with replacement tyres which has already been proven not to work......
How about we all solve the problem byd doing 7 point turns instead of 1 or 3? It'll 3rd take slightly longer to get where we're going but they'll be no more clunking/crabbing..... maybe.
