BillyW124
- Oct 22, 2010
- Location
- North West London
- W124 E320 coupe, W211 E320 V6 CDI, W211 E63 V8 AMG, R129 SL 280 V6, W215 CL 600 V12 Bi Turbo.
If you are going down the Sportline route is there anything you need to to do the Idler arm, I had a feeling that was Sportline unique as well as the Lower Control Arms. Something to do with ball point position, are you guys aware of this...??
As far as I know the idler arm is the same on both standard and sportline setups, though I could be proved wrong.![]()
Well I guess they way to do this is to check part numbers....??
I checked part numbers and as far as i can see the idler arms are the same with no reference to a 'sports chassis' on EPC.
The lower control arms are differentiated with 'only used without sports chassis' and one's that are 'only applicable to sports chassis'.
...however one thing i did notice for the 320 control arms, they both have the same part number which is odd. sportline and non sportline. Maybe they have been all standardised now? ..
My next plan was to convert the car to a sportline spec minus the springs and shocks as i'll be getting something that suits me and the car as opposed.
This steering box was a big part of the sportline conversion so i'm not too sure what direction to steer with it at the moment now!
I'll be rebuilding the rear sub frame as I've got a refurbished unit with new Sportline bushes in them, (129 part numbers). Will need to get new links and arms for the rebuild to commence.
For now though its all about completing the engine conversion to its best and certainly a massive hats off to Carat.
He has done an incredible job and my expectations of a 'normal' engine conversion has been exceeded with the effort he has put in to make this thing look amazing and when finished drive like a beaut!
Little twiddly bits like cruise control, heated washer bottle, and other things here and there and the job's a good un!
I'm impressed how the black rocker cover has turned out.
Just ordered a new brake booster line and coolant expansion tank so on its way
