C280 V6 (M112) Engine oil filter
Grahamcol
West Midlands
2007 CLK 220 and 2001 SLK230
One of the other members helped me out a few months ago with regard to the oil filter element for my M111 engined C200 (It was grober who assisted). I now need to do a similar oil and filter change on my M112 V6 C280. Is it going to be as per the C200 without washers and things? I have a feeling not but if anyone can let me know exactly what the fitting / assembly consists of (Grober ?) then I will feel confident to tackle this job myself. Thanks.
Pretty much the same. The oil filter is in the same area.
Hi Grober,
Many many thanks. That's exactly what I wanted. Foolproof.
Regards.
GRAHAM
You can get a special tool to fit the plastic hex head of the oil filter housing from halfords, as it can be sometimes a little tight and fitting the standard chain remover mauls up the the plastic a bit.
The tool mates with a socket set extension bar.
Thanks for this good suggestion Desilva. Actually I've already got one but thanks again anyway.
