Apropos of not much really...but, had a Rolec Chargepoint installed on Monday - all good. Much more convenient with the tethered cable than it is messing with the wall-wart supplied with the car. Faster charging too of course, FWIW. That said, I might revert to a lower rate of charging to give all the systems an easier life.
Took the car in today to have a rattle at idle examined. Of course, it didn't do it when I got there.... This isn't the 'normal' noise this engine makes, you know, the one that makes you think you bought a reasonably quiet diesel powered car by mistake, this was a full-on bag of spanners in a tumble dryer type racket that sounded like a metallic cover resonating as the engine hit 1200 rpm. I had an old Jeep Cherokee that sounded much the same - the core of the CAT had come loose inside the casing. Anyhoo, while it was going in, I asked if my car needed the charging socket and cable replacing and apparently not, it was sorted in production. August 2016 build I think.
Car is going back on Monday so they can keep it overnight and see if it will oblige with the noise when its cold.
Good service so far. Have to say, I certainly got the feeling you get when you book a doctors appointment then feel fine by the time you get there. I think I'll fire the car up tomorrow morning while its nice and cold and see if it'll oblige. I'll record it if it does.
I've been doing my driving in Sport or Sport+ to put some miles on the ICE. I prefer Sport+ on the whole, mostly due to the gearbox holding a lower gear I think. Some of the low speed light throttle gear shifts seem less than perfect at times though, oddly, they seem slightly worse in Comfort mode. I am being picky here though.
Overall, happy/10.
@paulhx - could you perhaps get a Type 2 extension cable? I haven't looked, but maybe the Type 2 charge cable that came with the car would work? If I remember I'll have look tomorrow.
I only have the one car that needs to charge (so far!) but I'm fortunate in having a reasonably long drive so could place the charger at a position where it'll reach the car with the 5m cable whether it's parked at the front or back of the queue.
