CaptainChaos
COMAND.Thanks, is it Audio20 or Command?
Seems like there are only a few options left:Yeah that's the exact issue with mine seekay. Like yourself, I tried it over and over again fooling myself thinking that my fingers will be quick enough next time and it won't bounce back!
It is something that doesn't bother me hugely but if you do find a solution I would certainly also try to implement it/ have it implemented.
COMAND vs Audio 20?? Headology pure and simple. There can’t be more than a few quid difference between actual hardware costs but put in a (slightly) bigger screen and a couple of extra features and you’ve generated an upgrade people will pay through the nose for. Combine that with some carefully thought out package bundling and you sell people a load of stuff they don’t want to get one or two things they do, and make a much bigger profit while you do it. Totally standard practice in this industry and many others.Realistically it sounds like 1 & 5 are your options.
Out of interest do we know what is the breakdown between cars that have Comand and Audio20? Also, why weren't all cars installed with Comand?
An IS300h sounds appealing though. I did look at one before buying my C350e but didn’t much like the American style interior. Wish I'd got over that!
True, not worth it but I just hate things when they don’t work as they’re supposed to.6) Be grateful this is all you have to worry about.
I know it's annoying, but is it really worth all this fuss? Selling the car because of it?!
All that's happening is that the passenger seat is coming on. When you get in the car you can lean across and switch it off. Once the weather warms up you won't be pre-heating anyway.
I wonder if the car senses body attitude as well as suspension position?
That makes sense about measuring to the centre of the hub. Will need the spirit level as well to ensure I have a flat surface!!I suppose you would need the car on a perfectly flat surface and measure from the wheel arch to the centre of the hub. I think it would be difficult to measure accurately against the tyre.
Yeah that’s what I did, measured from top of the tyres to the wheel arch. I don’t know how I discovered it, I’m always looking for faults in the car, bad habit I know.@seekay How did you discover the suspension is lower in one side? You have just given me another activity, which is always good in these times. Out of interest I will check whether I have a similar issue. I take it you measure from the top of the tyres to the wheel arch?
On a separate note, had an opportunity so brought my car in to main dealer where I bought the car and they are consulting with Mercedes on the yellow EML. Haven't gotten my iCarsoft delivered yet.
I meant another C350e user posted that his car wouldn’t start as it detected the cable was attached to the charging port when actually wasn’t.Not sure what the nightmare with the charging port is, but at 1200 miles each way, would not being able to charge make much difference?
I wouldn’t expect a thorough check of anything unless you explicitly asked them to do it, and even then....I meant another C350e user posted that his car wouldn’t start as it detected the cable was attached to the charging port when actually wasn’t.
@Chris-S
We’ve been doing these trips for more than 8 years now, always had German cars, Audi and BMW, just regular diesels, had a standard European breakdown cover and that’s it, we never had any concerns until we got this car, but here I saw so many stories...
For example is there any sign that the AIRMATIC will go wrong soon or just suddenly happens without any prior warning or symptoms?
Saw in this forum some users had “Car too low, STOP” message on dash... hopefully I never have to read this. When I take the car to an annual service and they do the vehicle health check it would turn out if there will be some problem with the suspension in the near future?
