C36 brake fluid change. Couple of questions please
cazyp
C43, Hilux
Hi want to do a brake fluid change. Car has no traction control just abs.
Is merc dot 4 plus the correct fluid?
I have read I need to actuate some valve on the master cylinder? Help! Please!
I'll use my pressurised changer - around 2psi ok?
As for order of bleeding.. Rear left/right front left/right? Assuming left is drivers side.
Many thanks.
