Mad Mike
New to the forum, I'm hoping one of you Comand experts out there can please advise me on a problem I now have with my Comand DX in an '03 W203.
When stationary and switching on the Comand from cold, my position on the map is roughly right, but the direction the car is facing is usually wrong on the map. When moving, again my position on the map is roughly right, but the car direction shown on the map is varying all the time, taking excursions off road and randomly in all directions. This scenario continues for about an hour and a quarter of driving and then after this "warm up time", the Comand starts to work properly - back on road and the given position is correct to road junctions.
If switch it off and back on again after a short time, the Comand still works normally. Leaving it switched off for longer periods and I seem to have to go through a warm up time before it works properly.
Typically it receives between 5 and 7 satelites and has, I guess, the latest firmware (MB star display on start up, etc.).
I'm an electronics engineer by profession, working with instrumentation, but not Sat Nav units. My uneducated guess is a fault with the electronic compass/gyro. I'm confident that I have the skills to replace such a component, but am not sure if my diagnosis is right. Also I don't know the make/model of the gyro and where to purchase one. Trying to minimise the length of time the Comand would be out of the car, to have everything prepared beforehand would be helpful. (And not to have to open the unit up initially just to get part numbers etc).
Any advice greatly appreciated.
Kind regards,
Mike
Kind regards,
Mike
