Druk
Gone but not forgotten - RIP
- May 28, 2004
- Location
- Not far from Edinburgh.
- 2011 S212 E350CDi. 1981 R107 300TurboDiesel.
^ thought I'd said most of that?
Yep.You've checked the switch at the dash is in the off position?
They have no effect on anything. The lights stay on.Check the operation of both rear side door switches.
These are exactly the right colours.one of the wires on the back is brown/grey. The other should be brown. (just to confirm my older model wiring diagram is correct)
Could it be one of the switches of rear doors that I replaced?Somewhere or other that brown/grey wire is going to ground to cause the lights to be on.
Would you recommend that I replace or check these switches? I have a spare car to cannibalise from you see.
Just a thought, in view of the fact that you have been working on the rear doors, are the strike plates present at the door locks?
Any chance someone has a diagram, sketch or a picture of that microswitch?there is a micro switch in the rear lock mech which may be the problem? anyway good luck hope you sort it soon.
