miro said:
If the Diagnostic cant see it then how is the COMAND going to see it ?
The cables are not as they should be. Ring order is only marginally important. Pehaps we need to define "working".
Hi Miro - I seem to have read what Rosechap has said before in a different way to you, so yes we definetly need to define "working" !
(I'm being detailed with explanation here so it's useful for others)
I think that Star can not see COMAND at all (rather than it can see COMAND but not the CD changer) because its a W210 , and the W210 has the 38 pin diagnostic socket - which has different pins for Radio and for COMAND. As the car was upgraded from radio to comand. From what RoseChap said I do not think that the pin has been moved in the diagnosis socket from pin 33 to 34. Star uses COMAND as a gateway to the D2B bus (and to the CANbus that has the TV on it, known as a KINgateway and a CANgateway in diagnostic terms I think)
Lets start at the basics for Rose Chap to answer then see whether we can sort this out for him between us.
Before you added COMAND
(a) What head unit was there
(b) Was there a CD changer, or an integrated phone (with steering wheel controls), or linguatronic/vcs (voice recognition)
(c) Did it all work
When you added COMAND
(a) Did you move the diagnostic pin from 33 to 34 in the under-bonnet connector
(b) Did the CD player still work
(c) Did the phone (if fitted) still work
(d) When COMAND is turned on initially, do you see the MB Star and then a a screen with the DX logo
Please go into diagnostic mode (select AUX input by pressing SYS key, then selecting AUX). Then hold down the 3 buttons, MUTE, 1, 3 all together until diagnostic mode is entered.
- Now goto the configuration screen, and tell us what is ticked and the numbers in the bottom left
- press RET and goto diagnosis then D2B components
- does the actual column match the config column
- please tell us what is shown on that screen
- press RET and go into error list, pls tell us what is there, then hold down MUTE and 0 together to clear the error list
- press RET twice and go into versions, wind down the screen to D2B and go in there and tell us what is there
Richard
