richard said:
Please go into diagnostic mode (select AUX input by pressing SYS key, then selecting AUX). Then hold down the 3 buttons, MUTE, 1, 3 all together until diagnostic mode is entered.
- Now goto the configuration screen, and tell us what is ticked and the numbers in the bottom left
- press RET and goto diagnosis then D2B components
- does the actual column match the config column
- please tell us what is shown on that screen
- press RET and go into error list, pls tell us what is there, then hold down MUTE and 0 together to clear the error list
- press RET twice and go into versions, wind down the screen to D2B and go in there and tell us what is there
Hello again gents, thanks for all the replies so far.
Just to see if it helps, here are the answers to the questions posed by Richard.
Answer to 1.
TV Tuner: Not ticked
Telephone: Ticked
Telematic: Not ticked
Telematic via D2B: Not ticked
Analogous BOSE: Not ticked
Combi Self Aligned: Ticked
Answer to 3.
The actual column matches the config column in some cases and not others.
POS ACTUAL CONFIG
000 1C8 1C8
000 190 0F0
OFF 000 190
OFF 000 000
OFF 000 000
OFF 000 000
Answer to 5.
The error list had the following on it.
SPE Code Type CNT State
N1112 0X0000 021 P
B1767 0X0001 002 A
I cleared these errors with the instructions above.
Answer to 6.
Ser No. SW Ver. D2B Proto
Handy No No No
T-Aid No No No
SBS No No No
CDC 00087178 1.12 2.3
Sound No No No
According to the Russian website where you can see the spec of your car from the chassis number, I've got BOSE, should that be reported somewhere above? Or is it somethat that needs to be enabled?
Also, I should point out that the dealer DID enable Nav in the cluster display, but in doing so that stopped the CD changer from working. I value the CD changer more than Navigational arrows so had them change it back.
So, does the collective wisdom say that I need to swap the diagnostic pin over to resolve all the problems? Or does this issue run deeper than that?
I really do appreciate all the assistence so far.
Cheers,
Andy
