marek, i suspect you are looking in the wrong place. it has been suggested (w124coupe?) that this code actually refers to the throttle actuator, NOT the tps. if you have a read here it certainly seems so...
STAR TekInfo
the throttle body itself is possibly faulty, or the loom to it could have been disturbed when you did the work on spark plugs?? i have seen a similar problem with an ml500 before, the cure was to replace the loom, that was nearly three years ago now and still going strong. we did suspect the throttle body too, but on inspection it had already been changed before!
as has been said, some time with an independant specialist should pin it down clearly.
