We had the same problem when we first bought our ML,high fuel consumption(early 20's).
So to rectifiey our problem,was,to get the tracking sorted both front and REAR.
The motor was not crabing so the problem was not at first obvious, and there was slight wear on the inside of the tyres front,outside rear , So i put this down to a heavy right foot and throwing it into corners,
![Devil :devil: :devil:](/styles/mbclub/smilies/devil.gif)
But the tracking was out.
We got this done and problem solved,now low 30's ,tating around giving it some,(within reason).
The job needs to be done at the stealers though, as the ML needs to be preloaded to set it up right,
We had the settings off a 4 wheel alignment unit and tried to set it up at a mates garage but could not get the results, and it scuffed the tyres even more,because we did not preload the ML (this is what needs to be done),so that was an expensive (i'll do it my self job )
But we then booked it in at the stealers and they did it under preloaded conditions they also checked the condition of the associated rubber componants that control the steering geometery and hay prestoe every thing was oky doky.
This may solve your problem or may be not ,But this is what we did and it worked.
