Excidium78
PAUL R said:I can get the consumption to 22mpg with a certain style of driving ,but not all the while, something will break, and if you want to keep forking out then thats OK>
You should have brought a ML 55 AMG.paid once and thrash it, you will only bend it not break it.
To get 22mpg from a diesel ML your foot must be planted for quiet a long time,IF you want speed don't expect a high mpg. Like wise if you want mpg do not expect speed. (From the ML range).
Good luck at the stealership.
First of all i do not trash my car. I also do not drive 0 to 60 in one week. I normally only give 1/2 or 3/4 gas. hardly ever floor it.. and only used the kick down maybe 3 times....
As for engine noise YES it is LOUD... compared to a E class and or S class... The S has full insulation around the engine so i guess yeah you would hear less...
I just can not understand how other people can get such a great mileage and also drive so (sporty?). My Seal Leon (130HP 300NM) Used round the 37 MPG.... Wondering Why Volkswagen are so bad in making engines.
I mean to say... The ML is nearly 900 KG heavier in weight and 4 wheel drive... and use that little fuel... Imagine what 270 would do in a C class ;-)
So i guess it must be me... having a car that is in 100% working order. And So thirsty...
22 - 23 MPG is what it does...
