Thanks for the reply,
What precisley is 'angle tighten' ?
im wondering the same!
Both arms and made quite a 'crack' when it went, your limited to the force your able to apply because of the extension required to be over the lip -
I have loosened all the bolts off in reverse sequence, I wanted to try the wrench out on a wheel nut but dont have a 3/8 to 1/2 reducer -
Can anyone rec a good wrench, the ones on ebay are very similar twisting handle type, this looks ok
http://www.halfords.com/webapp/wcs/...1_productId_178843_langId_-1_categoryId_76866
Angle tighten is to tighten the bolt a further 90 degrees. For what they cost I would invest in a new set of head bolts to be absolutely sure they are all good.im wondering the same!
BTW the wrench shown is actually made by Norbar a top notch British company whose products are widely used in industry.
They come with calibration certificates. Mine are extremely accurate.
I have 1/2" and 3/3" ones.
It's a shame people buy rubbish Chinese made ones.
well put mate>> So do you tighten the bolt a further 90 degrees even though the torque wrench has 'clicked out' ?
Well, in your case, you'll actually tighten to 180 degrees after the last torque wrench operation. Two steps of 90 degress. This is why the torque value looks low to you - it is low, but the bolts are tightened through the further angle of 180 degrees.
The first two torque stages are just to snug the head down into position, and form a repeatable starting point for the angle tightening.
I'm glad that you're replacing all the bolts.
When doing the angle tighten part (there's a relatively cheap protractor available from motoring and tool shops that fits on your extension bar), you can soon get mixed up. I would recommend that before you begin, you mark, using some tippex or similar between the bolt and the head - preferably in a consistent way.
For example, if you put the mark pointing forwards, after the first 90 degree stage, you should see 22 marks all pointing towards the driver's side, after the second stage, 22 marks pointing towards the back of the car. This method ensures that you don't miss any (because you *can't* check with a torque wrench afterwards!)
IIRC head bolt should be at 55Nm then 90 degrees then a further 90 degrees. Purchase an angle gauge for the 90 degree bit, they cost less than a fiver. Also use a long breaker bar to ensure you get enough leverage in one shot of tightening.
55Nm seems to be the setting for petrol engine, the diesel version appears to have different settings for just about everything
Are you referring to the Halfords one or the one I bought from ebay ?
Yup, bolts already ordered - I think that the one pictured snapped at around 50/60 ft lb using my now working torque wrench as a guide - that said I dont have confidence in the tool which maybe further damaged by not clicking out -
Whats inside 'em - I am guessing its like the old volkswagon beetle suspension rod setup?
Just a spring and a sprocket, no more and no less
The Halfords one. It's the same as my Norbar 3/8" shown bellow.
As you can see I also like Facom but their torque wrenches are over a £100.
BTW always use new stretch bolts as the old ones fatigue regardless of length.
adam
Big X, do you use them or are they for display purposes only![]()
