Can you believe it after all that grief with the wrench the guy on fleabay refused to swap it or upgrade to a better brand even though I offered to pay the difference -
Hi Spock
While I sympathise with you for having broken the stud through your own mistake, I think you're being a little hard on the eBay seller and that to leave him negative feedback would be unfair. After all you have now used the torque wrench and possibly even damaged it (although hopefully not), so the seller could not re-sell the item. And it does sound very much as though it was your mistake - to actually snap the head stud would require a torque of at least 10 times the recommended initial torque figure!
On a more constructive note, when you tighten the new bolts always tighten at each stage in a single, smooth, continuous movement. In other words make sure that you don't stop turning until the torque wrench clicks at the pre-set figure (or until the correct reading appears on the scale). The reason for this is that the torque required to overcome the inital friction and start the bolt turning is higher than the torque required to keep it turning. Therefore if you stop just before the wrench clicks and then start again, you are likely to find that it will click before you have started turning it again. This means that the bolt will be tightened to a lower torque than you think.
Mike, I disagree, you are working on the assumption that I didnt hear the wrench click which is understandable.
I tried the wrench using a 12" adjustable spanner before going outside but nothing happened at 10ft lbs - my mistake was that I didnt realise what 10 or 27 fl lbs was supposed to feel like so I carried on in the hope it would work! a stupid and costly mistake I agree resulting in the snapped bolt.
The chap on Ebay states these are used on aircraft, I doubt that very much as they dont come with a certificate and the printed instructions are incorrect.
Also a wrench which claims to be accurate from 10 - 80 ft lbs (as I now know) will be inaccurate at the ends of each scale, so again unlikley to be used on aircraft.
Thanks for the advice on tightening, that makes sense and will take that onboard ater picking up the bolts tomorrow.
Picked up the Halfords wrench today :bannana: which feels like a nice bit of kit, complete with a March 08 certificate.
Chaps, thanks for all you advice and help
I shall try and post a few pics back once she's up and running!
