PJayUK
- Oct 6, 2008
- Location
- Surrey, United Kingdom
- ML320 W163, E320 W210 & Jaguar X300-XJR6
Hi Everyone
Seeing as its snowing and I am off work I thought I would try and install my latest gadget into my S320. Its one of those Harman & Kardon Ipod integration things (like this http://www.harmankardon.com/drive-1/default_dp1.aspx) and integrates an Ipod into your stereo.
There are 3 main option for connecting it, an integrated FM Transmitter, standard Phono Connectors or via a wired "tap" that connects between the head unit and the aerial. I was planning to go via the wired Aerial tap method but I am unsure how to get at this. Does it involve removing the entire command unit to get to?
Other though would be to simply remove the CD Changer and replace with this unit (assuming the changer is connected to the headunit via a phono lead).
Of course all of this would be oh so simple if there was an Aux input! I dont beleive my version of Comand has one (I think its comand V2.5)
What do you think any ideas how best to do this?
