HOWTO: Install Interior Dimming RVM - Pre Facelift W202
pluggers
Staffordshire
C250 AMG Line Premium Plus. W205
HOWTO: Install dimming RVM pre facelift W202
Just done My RVM today Big thanks to Ricky for supplying my mirrors so quick :bannana:
First switch off the interior light and ignition.
This is how it starts off,The original Rear view mirror.
For the pre facelift cars the interior light does not need to be removed,Just grab the mirror base and twist hard.
What you are trying to do is depress the pins on the ends of the spring inwards to release the mirror from the housing in the roof lining.
When it pops out the loom comes with it.
All that needs to be done now is unplug the old RVM and plug in the new dimming RVM,Push the connector into the mirror base and push home the RVM into the roof lining.All is done.
To check its working switch on the interior light
to normal operating position,switch on the ignition ,hold your finger over the light sensor on the back and shine a torch onto the sensor on the top corner and watch it go very dim :cool:
  • Like
Reactions: PJH
