For those who have a pre 1993, all alloy style mechanism, here's a comprehensive PDF on how to get at it:
web.mac.com/dakota/Mercedes/Projects_files/MonoWiperv2a_1.pdf
It looks a lot of work; is there a way of lubing it with the mechanism in-situ?
Hi all
I would like to comment on Parrots excellent thread as Alex has said the mechanism is significantly different from the one shown above compared to my 1994 C180 W202
The correct method to remove the large cover is to remove the hex screw with an allan key, see attached Pic C then pull the wiper arm away from the mechanism cover, it’s a tight fit so use a couple of jerks…if the don’t work try a couple of yanks, protect the windscreen with a thick cloth on top of thick cardboard to prevent brakage/scratching, there is a heavy spring under the wiper arm & mind your knuckles Refit in reverse order and don’t forget the hex screw. The hex screw can be better seen on Parrots 3rd Pic down immediately above the screwdriver
The lazy / quick method which I prefer is after removing the cover (Pic A is the cover in its original factory state) cut a groove as in Pic B which will negate the need to remove the wiper arm in future and makes the job much quicker and encourages frequent greasing of the mechanism.
The job takes me about 5 minutes about 4 to 5 times a year using ordinary general purpose grease.
As far as I know the stealers never grease the mechanism, it certainly is not in the scope of work in the maintenance booklet, it mentions Wipers yes but I don’t think the ever grease the mechanism, that’s why failure of the wiper mechanism is so common If this job isn’t done regularly the mechanism will dry out and cause extra strain on a weak compression joint inside the rear of wiper mechanism, seen in Pic D This was the cause of the failure of my wiper mechanism
Sorry I have no proper camera so used phone camera
Dec
