How fast do the batteries degrade? My iPhone battery after 18months is at 87% so a "full" charge is really only 87% and decreasing every year, I assume the batteries in electric cars will also do the same.
An interesting analogy.In contrast, when you own the battery, then you accept it will deteriorate over time, much like the tyres and brakes do etc.
I wonder how many ICE-powered vehicle owners would be accepting of a fuel tank that reduced in size with age and then cost up to 40% of the original vehicle purchase price to replace?
A friend of mine has a gen 1 Nissan leaf, its a 63 plate and he gets tops, 50 miles range out of it now, its done about 80K miles. Its become a paper weight. Its £3K to replace the battery so isn't economical to replace it.
Apart from long tern degradation, how well do they keep their charge if not used for a while? The equivalent of a leaky fuel tank.
We had to het an ev recovered into work a week or 2 ago as the car had sat for a while and the battery went flat and nothing would work on the car, 12v battery needed charging first before the ev battery was able to be charged
No idea if it’s typical, but in the C350e, the main 12V battery is a monster, plus the 12V auxiliary “battery” that’s actually a supercapacitor, plus the HV battery of course.The 12 volt battery in a typical hybrid will be significantly 'smaller' than a typical battery as it only has to start the computers.
Usual life is 2-3 weeks for a healthy example.
The traction (high voltage drive) battery will last many weeks though.
This is the case with Lexus hybrids, everything is powered by the traction battery (there is no starter motor, MG1 will spin the ICE to 1k revs before the ignition fires), once the 12v has booted the computers to the ready state. So, apart from booting the computers the 12v only powers the entry system and that goes to sleep after 10 days(?) inactivity.Hopefully most hybrids have moved over to using the traction motor for cranking the ICE as the starter is a weak point on the C350e
Am not sure sorry, wasnt my job when it came in, just helped push it in as it had to have go jacks on the back wheels as not even the handbrake would release! They are complete clusterfuck of a things I can tell you that though, then moving to 800v in a few years well thats a whole new ball game!Any idea how long the car was parked-up before the 12V battery died?
Most of the power for electric vehicles is produced using fossil fuels in power stations.
EV will make sense once all fuel is created using renewables.
Until then EV power is not clean due to where it comes from.
I have seen them parked up for months without an issue AND I even received one that had been submerged in a flood .The 12 volt battery in a typical hybrid will be significantly 'smaller' than a typical battery as it only has to start the computers.
Only 2 coal fire power stations in mainland UK both in Nottingham and one in Co Antrim and a number of gas fired power stations. What is amazing is according to OFGEM fossil fuels still account for 74% of our power https://www.ofgem.gov.uk/sites/default/files/docs/2006/04/13537-elecgenfactsfs.pdf I find that quite high.Most of the power for electric vehicles is produced using fossil fuels in power stations.
This from the USA!Only 2 coal fire power stations in mainland UK both in Nottingham and one in Co Antrim and a number of gas fired power stations. What is amazing is according to OFGEM fossil fuels still account for 74% of our power https://www.ofgem.gov.uk/sites/default/files/docs/2006/04/13537-elecgenfactsfs.pdf I find that quite high.
