If you were really untrusting you would take a sharp object with you and make a very clear mark on the existing head!![]()
Not sure how they can refuse your request ?
Its your car after all .... if you wanted to go in and smash the windscreen with a hammer , you could surely being that you own it ?
If they claim to replace the head then the old head would become their property and they could refuse the request.
tried to give the service manager a call to get a progress update and what method they're employing to fix things, the receptionist said he was "busy" and would call me back later, well they're now closed so guess I'll have to ring again in the morning.
Is that right, if they are using a helicoil or other thread repair, I don't have to accept it and can ask them to instead get a new head!? What if they're argument is that the repair is as good as if not better than new!? (Don't know for sure what method they're employing will find out in the morning and keep you posted.)
I would guess that the intended repair will indeed be a helicoil insert which, if carried out by a competent machine shop with the head off the block, would be a satisfactory repair (with one possible caveat depending upon the particular engine). Would anyone who is so anti helicoiling like to elaborate on the reason(s) for their opposition?
I'd leave them alone to repair your car, they've put their hands up and are fixing the car.
If you ring up and explain that a load of "experts" on a forum have better plans for the repair than a MB workshop....
"When I saw one done they rotated the crank to TDC on compression for that cylinder and stuffed a greasy tack rag down the plug hole. Drilled, tapped and helicoil inserted then rag fished out with all the swarf stuck to it. "
I am not against the helicoil approach, some say this method is used for repairs within the aviation industry, I would not be surprised as it seems to be an accepted/efficient/tested way of repair.
Personally all I would want, is a little communication, that is all.
I would be asking about the method of the helicoil repair, would the head be going off to an engineering firm e.t.c. ?? If so, great, no problem.
I understand these are questions which would probably not be met with any enthusiasm, in terms of an answer, but if I were willing to accept a repair as opposed to a new head, all I would want to know is that the head work is being sub contracted out to a specialist and not done 'in house' (see below)
This is an extract taken from a thread that discusses a similar situation...
Even though the above method would suffice, I would rather the head was removed and sent off....
Who caused the problem in the first place ?
Some MB dealership somewhere who owned up to it and are dealing with it.
OP's got a loaner, and his cars getting fixed, it's not the end of the world.
