Number_Cruncher
There's no problem at all with a heli-coil repair - if done properly.
In the area of engineering where I work, it isn't usual practice to thread directly into soft metals like Aluminium alloy, and wire thread inserts are thus routinely fitted to safety critical equipment from new.
The presence of fluctuating loads, whether from gas pressure or other mechanical sources isn't a problem.
Sometimes, the wire thread will unscrew with the spark plug at service time. If you obtain some spare wire thread inserts, they are very quick and easy to renew in-situ. It's only the initial installation, where the Aluminium alloy needs to have a new thread cut into it that is at all critical.
THE vital thing to get right when installing thread repairs of any kind is to be absolutely sure the new hole and new thread is absolutely square to the seating face. If not, the plug may not seal properly, and will impose a bending load on the plug body every time the cylinder fires.
