I absolutely love this car, And well now even more! The one thing Brutus my previous e55 had that spoilt me was the sweetest 5g gearbox i've known, it was nealy as smooth as a 7g, So you can imagine what it was like going from that to Silvia for the 1st time.
Having got the car back now from Merc's its changes have improved beyond comprehension from before, but there was the very slightest and im talkin .1% feeling of the change i could detect when it did from cold.
Also i failed to mention when i 1st got the car the Radiator top mounts, You know the 2x small pins that locate the Radiator into the top of the panel were loose! they hadn't completely come out but were partially out and unclipped.
I did clip these back in, so they were tight, very tight as they should be.
I got the car back from Waterhouse drove aprox 60 miles driving superbly as it was, Once home checking the levels i noticed the Radiator buffer were partially out again... Hummm........ I thought initially perhaps it was the engine mounts, so i checked these as i had before trying to rock the engine from side to side. NOTHING! tight as you like.
That left one thing in my mind, The Rear Gearbox mount! Id changed this on my other 2 211's i've had as a precaution! Well honestly ive never seen one in this sort of state!
2x 13mm hold this mount on the lower cross member, and 2x 16mm hold it to the gearbox with the use of a jack and piece of wood i had this mount changed within 15 mines so dead easy.
The Result the car is SPOT ON! gone any sort of hesitation, gone is all the snatchyness, You cant feel any gear changes!! this simply drives exactly like brutus's gearbox 100%!! i cannot believe how this along with the other work transformed this car! Im head over heals and tbf i do know my Mercs well, and i can tell even when the slightest thing is wrong. Silvia is like a new car. Anyway he is the replacement mount. Fitted perfect as usual and you can see the difference between old n new
Just thought id share my findings, Hope you Peeps are enjoying this thread. I know im certainly enjoying the car
