grober
MB Master
Sounds like what you are experiencing is a phenomenon known as "torque steer" where differential FWD can apply differing torque to alternate sides causing the car to slip sideways or shimmy --appearing to steer itself in the process and can be unnerving. This is caused by too much front torque or a lack of grip to the front tyre treads. So first question- is your car equipped with winter or all weather tyres at this time of year? This in itself may effect a cure.
OR
Its supposed that the new steering knuckles alter the caster and possibly camber of the front suspension to combat tyre skip on lock. Caster angle effects steering self centering and reducing that may increase a tendancy to torque steer under certain circumstances. However replacing the knuckles may have altered another steering geometry namely toe--they are all inter-related . Changing the caster angle may require a steering realigment --toe-- to re-adjusted to compensate for the new component- perhaps this wasn't done in this case?
OR
